How to install a hardtop with pics...
Old Oct 3, 2010 | 02:20 AM
  #131
HARDtoTOP's Avatar
Originally Posted by TTMartin,Oct 2 2010, 07:15 PM
Thanks, Great DIY, was a lot of help.
Only thing I changed, was instead of using a metal punch to 'pound the metal in'. I used a piece of hardwood dowl. This worked fine to bend the metal, but, did not damage the paint on the metal.
Great tip!
I edited the original post with that suggestion. Thanks.
Old Dec 19, 2010 | 11:55 AM
  #132
dhean's Avatar
Can anybody explain how to precisely measure the 184mm distance? It's not clear in the picture and in the official honda manual. I do not see any markings on my ht to use as marker.
THanks
Old Dec 19, 2010 | 09:24 PM
  #133
CBRdream21's Avatar
You are supposed to measure back 184 mm from the front edge of the rear quarter panel, then measure the gaps latched and unlatched at that point.
Old Dec 19, 2010 | 11:03 PM
  #134
dhean's Avatar
Yes, I realize it's from the front edge of the rear quarter panel, but to which point of the hard top? This is not clear.
Old Dec 20, 2010 | 04:01 AM
  #135
HARDtoTOP's Avatar
[QUOTE=dhean,Dec 20 2010, 03:03 AM]Yes, I realize it's from the front edge of the rear quarter panel, but to which point of the hard top?
Old Dec 20, 2010 | 05:59 AM
  #136
deepbluejh's Avatar
Nice... subscribing!
Old Dec 22, 2010 | 10:56 AM
  #137
dhean's Avatar
Originally Posted by HARDtoTOP,Dec 20 2010, 05:01 AM
Did you see this picture in the OP? There is no measurement that needs to be taken from the hardtop itself for it. Whatever part of the hardtop that aligns with the 184mm fender measurement is where you go from.
OK, so the 184mm is to be used in conjunction with the 8/14mm measurement. I thought the 184mm is used to adjust he horizontal gap between the hardtop and the front windshield as I believe my hardtop may be too far back and it's now rattling. The trunk comes very close to hitting the hardtop glass when it's opened.
Anybody have the specs for the gap between the top windshield and the front of the hardtop?
Old Dec 22, 2010 | 12:22 PM
  #138
HARDtoTOP's Avatar
Yes, the 184mm measurement is simply where to take the open and closed gap measurement.
I don't remember there being a measurement for the front latches area. I think as long as it's tight you are good. Don't over think it, it's just a hard top not a nuclear reactor.
Old Dec 23, 2010 | 08:13 PM
  #139
dhean's Avatar
Hard not to over think as the rattling has been getting so bad that it's more quiet to drive the car with the soft top up, or even with the top down!
Old Dec 23, 2010 | 08:47 PM
  #140
CBRdream21's Avatar
If your front latches are tight then that's all they need to be. Basically if you have to use a little bit of force to latch the front then it's fine, but if they close with almost no force then it's to loose. If they are to loose it has nothing to do with the front gap since it's not adjustable. The only way to tighten down the front is to either put some sort of wrap on the front strikers, or shim them. Most people that have any wear on their latches end up using one of these two methods to tighten it up.
When I open my trunk there is about a thumbs width between my trunk and my window.
