how lean is too lean....vafc dyno tuned today
Old Oct 18, 2002 | 02:07 PM
d2d's Avatar
d2d
I searched around for information on this...found one thread in perticular that discussed a super charged application but otherwise nothing.
Had my car dyno'd today. Guy asked just how lean I wanted to run. I let him now I wanted to make gains, but keep things safe.
So he basically told me that we'd avoid going over 14.0 and try to keep it between 13 and 14.
I made decent gains with this! Before we started to play with the vafc, I dyno'd at 180 peak hp (this is on a dyno dynamics setup). I was fairly happy with this...since stock I was at 202 on a dynojet...so it looks like the aem cai made a little power.
Once we finished up I was between 188 and 189 depending on the run. The run he printed out was just under 188.
But my question is..am I too lean running like this. He wasn't sure what tolerances the s2000 has. And if you look at the dyno link below you'll see I'm fairly close to, and in one instance exceed 14.
Advice would be appreciated.
the printout is at http://mathcs.holycross.edu/d2d/s2000/dyno...8-02.-small.jpg
Thanks...
Dave
Old Oct 18, 2002 | 02:11 PM
d2d's Avatar
d2d
err guess I didnt search well enough. Found a post that said to stay around 13.5. Still someone who knows more than I, if you could peak at my dyno chart and let me know what you think I'd appreciate it.
Old Oct 18, 2002 | 02:40 PM
ultimate lurker's Avatar
David, you are o.k. I assume your car has a catalytic converter in place? If so, the readings at the tailpipe will be 0.3-0.5 points leaner than they actually are coming out of the engine.
As such, 14.0 is probably at the maximum level (adjusted) that you'd want to be. You shouldn't have any problems at all - except maybe if you're trying to set a land speed record. Then you might want to richen it up :-)
UL
Old Oct 18, 2002 | 02:54 PM
d2d's Avatar
d2d
Thanks a bunch UL.
This stuff is all new to me...loads of fun though.
Old Oct 18, 2002 | 04:22 PM
cthree's Avatar
Administrator
looks like you made a nice gain there. I wouldn't worry about the 187 number tho. Every dyno is different.
Old Oct 18, 2002 | 05:15 PM
d2d's Avatar
d2d
Yeah I'm not worried. I was told about 15% lower and dyno dynamics than on dynojet.
When I dyno'd stock on a dynojet I was at 201 or 202...pretty sure I'm significantly above that now though with the intake and vafc. I'll find out when I feel like spending ~80$ for a couple runs at the local dynojet shop.
Hamiy
Jul 30, 2005 09:24 PM
JC_S2000
Feb 10, 2005 01:03 PM
s2khondaimport
Sep 28, 2004 06:30 PM
Nazgul
Jul 17, 2003 05:42 PM
Nazgul
Jul 17, 2003 07:30 AM
