how much diff. fluid
Old Jan 23, 2009 | 02:10 PM
silvery2ks2k's Avatar
Default how much diff. fluid
is that going to be enough for daily driving no one mentioned how much of a pain in the ass gettin the fluid in was the car was jacked up on the left side i got as much as i could in the rest i spilled any help would be appreciated.
Old Jan 23, 2009 | 02:13 PM
S2KenC's Avatar
Thats about right. 0.7-0.9 of a quart is what it will hold. Don't overfill it too much.
Old Jan 23, 2009 | 02:23 PM
vincewchan's Avatar
Jack up the car and keep it on ground level. Once it starts leaking out from the Fill hole, your good.
If you don't have 4 jacks, use 2 jacks in the rear and jack up the front so the car can stay leveled.
Old Jan 23, 2009 | 04:04 PM
cdelena's Avatar
I usually put it a full quart. I was surprised that one dealership fills a new diff before installing to the very top putting in more lube than you could ever use... unless you stood the car on its nose.
Old Jan 23, 2009 | 05:15 PM
ok second question is i used royal purple it was like 16 buck a quart is it ok to mix different brands just to top it off? i dont want to pay another 16 for less than a quarter pint.
Old Jan 23, 2009 | 05:37 PM
s2k aok's Avatar
fill to spill (0.78 quart total, 2/3 mobile1 75w90 with 1/3 lucas)...
Old Jan 23, 2009 | 06:39 PM
what lol
Old Jan 23, 2009 | 07:01 PM
bgoetz's Avatar
Use the same fluid. When you are talking about a $20-$30K car, $16 is nothing.
Old Jan 23, 2009 | 07:31 PM
more like 11 but i see where your comin from at least ile have some readily available if i need it in the future
Old Jan 24, 2009 | 07:35 AM
s2k aok's Avatar
Originally Posted by silvery2ks2k' date='Jan 23 2009, 09:39 PM
what lol
fill to spill = fill it until it runs out the fill hole, you want the maximum that can be held by the assembly. i have a cocktail blend of mobile 75w90 ($9) and lucas ($9). the mobile is the main differential fluid but the lucas is there to stick on the gears and quiet the differential. s2kpuddydad recommended throwing in a little lucas. my 4.77s are smooth and quiet...
