how much diff. fluid
Old Jan 24, 2009 | 07:55 AM
NFRTurboTerror's Avatar
[quote name='bgoetz' date='Jan 23 2009, 10:01 PM'] Use the same fluid.
Old Jan 24, 2009 | 09:30 AM
INTJ's Avatar
Take a look at BITOG regarding mixing and lucas...
Old Jan 24, 2009 | 09:43 AM
JeremyStone's Avatar
Cliff notes?
Old Jan 24, 2009 | 04:58 PM
centralcoastbuc's Avatar
If you jack the car up from the side with the fill plug. Pump the whole quart in, then drop the car back down with a pan under it to catch the overflow, then jack it back up and install the plug, you only need one jack. This should of course be done on level ground.
Old Jan 24, 2009 | 07:10 PM
clawhammer's Avatar
Buy a 2nd bottle. It's not like it's going to waste, you can use it next time as well. It will make your life easier.
Old Jan 25, 2009 | 12:14 PM
a_zepeda926's Avatar
Originally Posted by silvery2ks2k' date='Jan 23 2009, 04:10 PM
is that going to be enough for daily driving no one mentioned how much of a pain in the ass gettin the fluid in was the car was jacked up on the left side i got as much as i could in the rest i spilled any help would be appreciated.
they make manual pumps to make this job much easier..
Old Jan 25, 2009 | 03:45 PM
aznives3's Avatar
i tried to use one of the dual action transfer pumps with one hose in the bottle and one hose in the diff/tranny...but i found it to be very messy. The pump that sits on top of the bottle and pumps into the tranny/diff through a tube works well too, but i just decided to get a funnel with a on/off valve and about 5 feet of clear tubing (~$2) which is probably the easiest method i've found so far. THe funnel i use also has measurements so its easier to hit the right fill volume the first time
Old Jan 25, 2009 | 04:23 PM
cdelena's Avatar
Exactly right! The tubing and a funnel is all I have used for filling either the trans or diff for years now and I still don't understand why so many fool with pumps.
Old Jan 25, 2009 | 05:12 PM
tlee1234's Avatar
le 607
Old Jan 26, 2009 | 08:20 AM
INTJ's Avatar
Originally Posted by JeremyStone' date='Jan 24 2009, 10:43 AM
Cliff notes?
Bad foaming. The cool gear climbing doesn't work. Generic rule of thumb, skip additives.
s2k bandit
Aug 20, 2009 08:53 PM
03_BB_S2K
May 17, 2009 01:52 PM
dmw16
Jan 25, 2007 08:05 AM
mic_crispy
Apr 11, 2006 04:59 PM
yarou
Jan 16, 2006 07:06 AM
