how much for new slave cylinder & labor?
Old Jan 23, 2006 | 10:54 AM
Scot's Avatar
Default how much for new slave cylinder & labor?
how much would a normal price be for a slave cylnder and installation? Mine is apparently leaking. Just thought I would prepare for the worst, just in case it needs replaced.
thanks
Old Jan 23, 2006 | 11:11 AM
SIIK2NR's Avatar
$50 bucks or around there.....
Labor?.... free.... it's so easy to DIY.
Tim
Old Jan 23, 2006 | 11:12 AM
VAD's Avatar
VAD
I think they are about $50. Labor shouldn't be too bad. I know two guys who did it in an hour while drinking.
Old Jan 23, 2006 | 11:13 AM
dozen5's Avatar
look here
hardtopguy
i think you could probably install it yourself. bleeding the clutch may require the most labor. good luck
Old Jan 23, 2006 | 11:14 AM
SIIK2NR's Avatar
Edit....
$56.95 at Hardtopguy...
http://www.hardtopguy.com/store/customer/s...substring=slave
Old Jan 23, 2006 | 11:27 AM
Scot's Avatar
so $70.00 from my honda dealer and pay a mechanic half an hour to install? sounds like a plan. I suck at doing anything mechanical other than changing brake pads, oil and rotors.
Old Jan 23, 2006 | 11:31 AM
johnny's Avatar
must... install 03 slave...
Old Jan 23, 2006 | 11:53 AM
SIIK2NR's Avatar
Scot..... If you can change rotors and pads... you can easily change the slave cylinder...
Buy it and install yourself.. go to the clutch delay removal threads for the write up on how to DIY...
Tim
Old Jan 23, 2006 | 12:14 PM
Scot's Avatar
Tim
did i mention it is cold as f-uck around here and i am lazy????
Old Jan 23, 2006 | 01:05 PM
S2000GT's Avatar
