How often do you change diff. oil?
Old Nov 3, 2003 | 10:07 AM
charles02's Avatar
Default How often do you change diff. oil?
I have 20,000 miles on my '02. I don't track the car. When should I change the differential oil? Just wondering if it needs to be changed more often because of the limited slip. I have full lockers in the front and rear of my 4Runner, and the oil needs to be changed at least once a year, dependant upon mileage and whatever off-road beating I put it through.
Thanks.
Old Nov 3, 2003 | 10:22 AM
Gloffer's Avatar
I change the diff and tranny fluids every other engine oil change. Since I'm running Mobil 1 oil, I change the engine oil every 5000 miles. Bottom line is: every 5000 on the engine and every 10000 on the tranny and diff. Makes it kind of easy to remember too.
If I were you I'd change your diff oil now. Make sure you use a GL-5 rated fluid.
Look here for all the info you'll ever need on fluid changes: http://forums.s2ki.com/forums/showthread.p...threadid=108435
Old Nov 3, 2003 | 10:40 AM
Gernby's Avatar
Former Sponsor
I also change my diff oil every other time I change my engine oil. The 1st change is the most important, due to break-in. I wish I would have changed my diff oil at 1K miles.
wortham's Avatar
yep. i would have suggested 10k on both myself. i haven't looked in the helms lately, but i think it recommends a much longer interval. i see nothing wrong with shortening it though.
Old Nov 3, 2003 | 10:46 AM
honda606's Avatar
Changed my diff. oil the first time at 3,500 miles when I did the first oil change.
Changed it again at 10,000 miles and will do so every 7,500 from now on.
Old Nov 3, 2003 | 11:39 AM
cdelena's Avatar
The AHM severe service recommendation is every year or 15K miles.
Old Nov 3, 2003 | 11:59 AM
Gernby's Avatar
Former Sponsor
True, but more frequent maintenance might help prevent some of the failures that seem to be so common.
Old Nov 3, 2003 | 03:57 PM
charles02's Avatar
Wow, thanks for all of the replies. Guess I better schedule an appointment.
Old Nov 3, 2003 | 04:39 PM
cdelena's Avatar
[QUOTE]Originally posted by gernby
Old Nov 3, 2003 | 05:41 PM
Road Rage's Avatar
I agree - I admit to being a maintenance fanatic, and well known for being a lube fanatic, but changing the diff oil every year is a bit over the top, even for me. I do changes at 1k miles, 1 year, and then every 2-3 years after that. The failures that have been described were shock-induiced mechanical ones, and Queen Elizabeth's tears would not have prevented those sort of failures.
