How often do you change diff. oil?
Old Nov 7, 2003 | 05:08 AM
  #21
aceprince's Avatar
is diff/tranny fluid the same thing, or do u need 2 different types of oil.....cause im taking my car into honda for the 15k servce...and im already using Mobil 1 for engine oil...but i was told to also swtich to Mobil 1 for "gear oil".....sooooooooo is gear oil the same as tranny and diff oil?
Old Nov 7, 2003 | 10:57 AM
  #22
Gloffer's Avatar
No, diff oil is different from tranny oil. You need two different types of fluid. A lot of us are using Mobil Synthetic Gear Lubricant SAE 75W-90 in the differential, and Honda Manual Transmission Fluid Honda Genuine HG in the transmission.
Look here for the two different threads one for the tranny and one for the differential for additional info: http://forums.s2ki.com/forums/showthread.p...threadid=108435
Old May 22, 2007 | 07:30 AM
  #23
tdrag97's Avatar
Ok.. I'm at 800miles now., should I start to plan on changing my diff oil @ 1k? and should I also change my oil then too?
Old May 22, 2007 | 07:54 AM
  #24
centralcoastbuc's Avatar
Every 15K
Old May 22, 2007 | 10:44 AM
  #25
Kenpo_S2000's Avatar
This is probably a dumb question but I have never owned a car where I had to have the dif. oil changed. Does have the dif. oil changed make the transmission shifting any smoother? Sorry for the noob question if this has been asked before.
Old May 22, 2007 | 11:07 AM
  #26
vtec9's Avatar
differential is at the back of the car.. its what transfers power from the driveshaft (being driven by the transmission) to each rear wheel. Since it has gears inside, it requires a lubricant, which ultimately breaks down and needs replacement.
To improve tranny shifting, you replace transmission fluid..
two separate things.
Old May 22, 2007 | 11:15 AM
  #27
Okay so when people talk about breaking their diffs from the launches it just because it can't handle the power. Thanks for the info.
Old May 25, 2007 | 02:21 PM
  #28
iam7head's Avatar
maybe all your previous car ar FR or MR? those are transaxle.
on a Front midship layout on the s2k(transmission), we have one rear diff in the back of the car.
you have three diff for awd cars like dsm
Old May 26, 2007 | 09:55 AM
  #29
tdrag97's Avatar
so should I change my Diff oil @ 1000k?
Old May 26, 2007 | 10:04 AM
  #30
AirborneS2K's Avatar
ahahahahahhaa You're not serious are you?
DEEZ
Mar 7, 2006 07:23 PM
321contact
Nov 19, 2005 11:21 AM
AGW
Sep 12, 2003 10:41 AM
Gernby
Apr 11, 2003 10:02 AM
