How To Remove Cluster Trim?!?!
Old Apr 14, 2008 | 04:54 PM
HighwayStar's Avatar
Default How To Remove Cluster Trim?!?!
I got an AP1 Sliver Cluster trim to replace my balck one. I am trying to remove the trim that goes around the guages....you know the piece that the audio and climate controlls are attached to. Does anyone know how to get it out?? I look at old post but they didnt have pic or they were dead links Thanks
Old May 26, 2008 | 03:31 PM
LEGEND_101's Avatar
I too would like to know this info. Anyone? Anyone at all?
Old May 26, 2008 | 04:22 PM
Stratocaster's Avatar
  1. Remove the two small screws holding the lower steering wheel cover.
  2. Loosen the two nuts holding the steering wheel, until they are barely still on the bolts. This will drop the steering wheel about 2-3"
  3. Remove the covers on the two screws on the top, underside of the bezel. They are located at the 11 o'clock and 1 o'clock about 2.3" from the speedo. This will take a thin, small screw driver or pick.
  4. Remove the two screws
  5. Using your finger, from the right lower corner, start to pull the bezel away from the dash working you fingers around the bezel.
  6. You will need to disconnect both controls from their wiring harness.
Sorry no pictures and it was written from memory.
Old May 26, 2008 | 07:37 PM
Thank for the info i will post pics when i give it a try but that gonna be a while. I want to paint it frist.
Old May 15, 2010 | 10:18 AM
ThePartsGuy's Avatar
Good Thread
Old May 15, 2010 | 10:41 AM
suzuka-blue-s2k's Avatar
In this thread he show's a few pics on what to do to remove it. Hope it helps you some! Trust me it is very easy to get remove and replace it. One tip would be to put some masking tape on the edges of the trim bezel where it is closest to the steering wheel. People always get chips and mess up their bezel there from taking it off and on.
https://www.s2ki.com/forums/index.ph...ic=601913&st=0
Edit: Here is a pic of where you should put some tape to avoid any marks on it.
chung
Aug 24, 2011 10:44 PM
evangelo
Jun 17, 2007 05:56 PM
Rdriver
Sep 19, 2006 09:05 PM
AusS2000
Jun 10, 2005 07:32 PM
aznhomie
Feb 18, 2004 07:21 PM
