how to remove O2 sensor?
Old Dec 8, 2005 | 01:20 PM
asdfg123hk's Avatar
Default how to remove O2 sensor?
hey
i was trying to install a test pipe, but i couldn't get the sensor off the cat. it's really tight and i tried using liquid wrench.
thanks
Old Dec 8, 2005 | 01:32 PM
Samer327's Avatar
A good penetrating lubricant and let it soak over night. Is you can't remove it with a wrench you might have to get an O2 socket to remove it. Some sensors can't be removed as they're too far rusted.
Old Dec 8, 2005 | 01:48 PM
xviper's Avatar
Make sure the wrench you use is the exact size for the sensor. I had to whack mine with a hammer to break it loose. After that, it unscrews in your hand. You will also notice that as you unscrew it, the wire gets all twisted up. Try to turn the cat instead and when putting on the test pipe, turn it onto the sensor before putting the pipe on the car. This will make for less twisting.
Old Dec 8, 2005 | 01:50 PM
asdfg123hk's Avatar
crap. i used those adjustable wrench on the O2 sensor.
this mod is harder than i first expected.
Old Dec 8, 2005 | 05:43 PM
boyguan's Avatar
i used a cresant wrench for it
no problems at all
Old Dec 8, 2005 | 07:27 PM
xviper's Avatar
no problems at all
This is true, but the crescent wrench should be large enough that the "pinchers" completely cover the 2 opposing flat surfaces of the sensor. If you use a crescent wrench that is too small, it will tend to slip and round off the corners of the sensor.
earri
Jun 13, 2008 02:10 PM
TheCarGuy2021
Jun 19, 2007 02:07 PM
JSWhaler
Mar 23, 2006 04:49 PM
Dolemike
Feb 4, 2005 07:42 AM
Dolemike
Dec 15, 2004 01:33 PM
