How to remove spare tire
Old Aug 13, 2015 | 06:53 PM
namedonelettere's Avatar
Default How to remove spare tire
I see the spare tire has a section that looks like it can be twisted,
I cant seem to twist it by hand.
Do you remove spare tire by twisting the center thing or how do you remove spare tire ?
Old Aug 13, 2015 | 07:17 PM
Keo209's Avatar
Yea the gold piece in the middle should be holding it down with a rectangular plate, it just twists off. It's probably just super tight to prevent it from coming loose and rattling since it seems to be a common problem.
Old Aug 13, 2015 | 09:14 PM
Yeah iT was just way too tight which makes it useless in an emergency situation since I needed to you pliers
Old Aug 14, 2015 | 12:40 AM
Gotpepsi's Avatar
You can probably find a rock or something to hit it and loosen it. But anyways, in the case where your rear tire goes flat, make sure that you move one of the front tires to the back and put the donut in front. The rear diff will get damaged driving on a donut.
Old Aug 14, 2015 | 09:28 AM
Conedodger's Avatar
Sometimes grabbing the spare and moving it while turning the wing nut will allow it turn easier.
Old Aug 14, 2015 | 12:38 PM
Themikewoo's Avatar
Place a flat object (piece of wood) against the edge of the gold T bolt. Gently hammer the flat object and it should loosen.
Once you remove the T bolt, I would put nickle anti-sieze on the thread to prevent this from ever happening again. Also inspect the face of the spare tire, my guess is that the face is stuck to the body of the car.
Let us know if you get spare tire out.
FYI inflate the tire to 60 psi.
Old Aug 14, 2015 | 02:52 PM
Yaupon's Avatar
Awesome information. Thank you for sharing.
MaxAP1
Aug 17, 2016 10:03 PM
TougeHorseman
79
May 27, 2012 01:29 AM
TW00Si
Mar 30, 2009 12:07 PM
super-S2
Sep 19, 2007 02:06 AM
