How to Remove Start Button?
Old Jan 27, 2021 | 04:23 PM
Edbun's Avatar
Default Bulb cover
When I had to replace the bulb in my start button, I noted that the bulb has a little tiny red condom on it to make the light reddish. I removed it to see what happened to the lighting. Turns out that the light, once the condom is removed, is almost a perfect match for the orange/amber of our dash cluster. Looks tons better and is a bit more noticeable.
Just letting you know. This is in my '06, btw
Old Jan 27, 2021 | 06:32 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by zeroptzero
I believe it comes on with the headlights. It helps to keep the button clean too, to allow light to shine outwards.
Start button will illuminate any time the key is on.
Old Jan 31, 2021 | 01:26 PM
wirebrat's Avatar
@Billman250 Thanks for the advice! Given you did not mention the lug on the other side, that confirmed for me that the tab was the only thing I needed to press to get the thing moving. I did press the tab firmly and at the same time pushed and cocked the start button a tad to begin pushing it out. It came out super-easy! A little guidance / affirmation can go a long way.
My dash has now been completely re-bulbed and the start button I replaced looks marvelous!
The illumination is pronounced due to having my iPhone in night mode when taking the picture. While I toyed with using a brighter bulb for the start button, I elected to stick with original bulb type. The amber bulbs used for the radio dash controls are a little brighter and of the same rating, but after comparing the two I preferred the reddish tint. YMMV.
Old Jan 31, 2021 | 07:00 PM
shrykhar's Avatar
Took a second look at mine and popped it out with a bit more force than I originally thought it would need. Cocking the start button to the side also depressed the metal tab so I didn't need to do that separately. Thanks Billman.
mertb
Dark Side Classifieds
Jun 29, 2016 05:20 PM
AP1Driver
Mar 20, 2016 10:45 PM
Toms1989
Jan 13, 2016 09:14 AM
EkaL86
Aug 3, 2015 10:53 AM
