How to stake axle nut?
Old May 30, 2009 | 11:47 AM
gtg749m's Avatar
Default How to stake axle nut?
I have the creaking/popping noise coming from my rear. I picked up a couple of axle nuts today and plan on changing them out to see if that is indeed the problem.
Couple questions..
1) Are there any special tools to unstake/stake?
2) What type of grease are you using? Can I use the Shin-Itsu?
Thanks
Old May 30, 2009 | 12:32 PM
starchland's Avatar
I would personally use a whit lithium grease or something hightemp/water resistant on there.
to stake, I use a chisel and a hammer...you just want punch the metal lip into the appropriate area of the axle.
Old May 30, 2009 | 01:53 PM
NNY S2k's Avatar
Common axel grease works fine.
Old May 30, 2009 | 05:01 PM
CKit's Avatar
Agree with people above. Hammer and screwdriver works okay. You do need to fold the lip back on the old nut before trying to unscrew them.
Axle nut is 36mm and don't forget to torque to 220ft*lbs (increased from the original spec 180ft*lbs).
Generally the driver's nut is the one that comes loose. The passenger side tightens up when launching....
And don't use silicone grease (Shin Etsu).
Old May 30, 2009 | 05:10 PM
gtg749m's Avatar
has anyone had problems getting the original axle nut off? ive read somewhere where it was almost impossible without an impact wrench. What was your method of getting if off?
thanks!
Old May 30, 2009 | 09:01 PM
CKit's Avatar
1. unstake the nut.
2. 36mm socket.
3. Breaker bar.
Old May 30, 2009 | 09:07 PM
Homer Simpson's Avatar
I've never had any luckk with a breaker bar....
I've used my long handle from my jack!
More leverage!
Old May 30, 2009 | 09:10 PM
zzziippyyy's Avatar
^ that qualifys as a breaker bar
Old May 31, 2009 | 02:36 AM
NNY S2k's Avatar
I used an impact wrench.
Old Jun 2, 2009 | 03:00 PM
d4vid's Avatar
sorry to thread jack.. i get that noise when I drive off every time. Do you think Honda will fix it under warranty?
