How to stake axle nut?
Old Jun 2, 2009 | 03:55 PM
CKit's Avatar
You're out of warranty, aren't you?
They might good will it, but just find a friend with a 36mm socket and a breaker bar. You're in LA, I'm sure you can find someone.
Old Aug 9, 2012 | 09:00 AM
ipopvtec's Avatar
Hey man when you heard the popping noise coming from the rear did changing and torquing the spindle nuts work? Please let me know because this is happening to me.
Old Aug 9, 2012 | 09:05 AM
DL771's Avatar
my popping noises disappeared after replacing and applying the higher torque spec to the axle nuts.
Old Aug 9, 2012 | 10:42 AM
Chugs's Avatar
You don't need to use new nuts, since you won't be able to confirm the higher torque than it was previously at, by comparing the old stake mark to the new one. I would re-use the nuts, there is nothing wrong with the ones on the car.
Old Aug 9, 2012 | 11:24 AM
s2k-tilldeath's Avatar
Old Aug 9, 2012 | 07:04 PM
mattstryfe's Avatar
I would also like to point out that the purpose of the grease (learned from Billman250) is to enable you to get to 220ft lbs. Otherwise there is to much friction and a human will be unable to torque it to 'spec' no matter how many breaker bars you use.
For reference, I used this method nearly a year ago and have had zero occurrences since. It's often said that unless you know it's been done properly every single car owner should do this as a preventative thing.
Additionally, this guide is fantastic and outlines every step with reasoning; very well.
https://www.s2ki.com/...le-nut-tsb-diy/
good luck.
Old Aug 9, 2012 | 07:14 PM
S2KIrishman's Avatar
did mine and my popping stopped, so i definantly recommend getting it done
levn
Mar 19, 2019 03:14 PM
MrWant
Feb 19, 2012 09:23 AM
mic_crispy
Nov 16, 2008 05:44 AM
jert534
Aug 9, 2006 08:19 PM
mic_crispy
21
Mar 18, 2006 05:49 AM
