humming sound.....
Old Dec 26, 2007 | 05:57 PM
  #31
pinoyk20's Avatar
hi guys the royal purple oil that i am using is 75w90.. do you think its not suitable for my diff??? thanks!!!
Old Dec 26, 2007 | 05:58 PM
  #32
pinoyk20's Avatar
Originally Posted by jirro22,Dec 26 2007, 01:33 PM
just give it a shot... it may work or may not work..but good luck...
just a question.. are you in the Philippines? if u ar, its hella hot and humid out there and you might be really using the wrong oil and the oil myt not be doing its job.
yes sir im in the philippines. its super hot in here. yah i thought of that also............
Old Dec 26, 2007 | 09:54 PM
  #33
jyeung528's Avatar
probably not, but it shouldn't cause a problem so quickly...
i'd still switch it out.
good luck finding the issue.
Old Dec 26, 2007 | 10:31 PM
  #34
pinoyk20's Avatar
ho guys!! i have with me a HNODA MTF that is being sold here in the philippines. the thing is that it doesnt say what viscocity it has... im not sure if we have the same MTF oil but this one is made by IDEMITSU LUBE singapore... is this the same HONDA MTF that you are using on your trasnsmission??? thanks!!!!
the code is P/NO.08267-p99-01ZS1
Old Dec 26, 2007 | 10:33 PM
  #35
pinoyk20's Avatar
yup ill be switchin it out.. but the problem is no one is selling LE 607 here in the philippines.. are there any other oil alternatives that i can use???? how about motul?? thanks!!!
Old Dec 26, 2007 | 10:51 PM
  #36
jyeung528's Avatar
amsoil 75 110
Old Dec 26, 2007 | 10:52 PM
  #37
jyeung528's Avatar
whether or not...i doubt the tranny fluid is the issue.
Old Dec 26, 2007 | 10:56 PM
  #38
pinoyk20's Avatar
ouch still no amsoil here.. we only have motul.royalpurple,castrol,total thats the diff oils that we have here.
Old Dec 27, 2007 | 12:45 AM
  #39
jurn's Avatar
You can order LE1605 from Ricks. It is probably the better suited for the warm climate in your area. In the mean time you can try some other GL5 75w110 oil or even 75w140. It might be the oil thats to thin for your hot climate.
Old Dec 27, 2007 | 07:11 AM
  #40
pinoyk20's Avatar
this is for the differential?? thanks!! whats GL5?? sorry......
