hydrolock help please
Old Jun 20, 2003 | 02:35 PM
mustangkiller's Avatar
Default hydrolock help please
i've had the aem cai for two years know and today it happened
it was parked all day not even in a puddle I started it it ran ok pulled out of my spot and thats it I didn't try to restart it pulled the intake off and full of water is there anyway of fixing it without changing the whole motor i checked the oil and no traces of water are visible please help
Old Jun 20, 2003 | 02:41 PM
Strike's Avatar
You can try what LordMagnet tried in this thread:
https://www.s2ki.com/forums/showthread.php?...threadid=130727
Old Jun 20, 2003 | 02:51 PM
strike i thank you very much i hope it works
Old Jun 20, 2003 | 07:49 PM
Strike's Avatar
No problem. Good luck with your car.
Old Jun 21, 2003 | 01:21 PM
I'd like to thank lordmagnet and strike for the advice but the sad news is another broke s2k pulled a compression test and no.1 cly.
is dead must have bent valve or hole in piston hopefully it will be covered ill let you guys know sending it out on monday
Old Jun 21, 2003 | 01:30 PM
hyperpm's Avatar
So I guess it's not running over a puddle or going through flooded area but rain collecting in the filter area from water dripping through hood/headlight opening.
Old Jun 23, 2003 | 02:24 PM
don't know how it happened but its fixed worked on it all day sat.
couldn't get it running just kept cranking over checked compression . Nothing in no.1 cyl.so i gave up and said i'd have it towed to the dealer on monday. here it is monday just for shits and giggles I crank it over' it starts and purrs like a kitten.
dont understand.
so if any body has hydrolock get the water out and dont panic there is a chance thanks to everyone for the advice and support
Old Jun 23, 2003 | 03:03 PM
Kodokan_4's Avatar
No compression in one cylinder, nothing is fixed, then it's purring like a kitten!
What's wrong with this picture?
Is it possible to have a valve not fully close, and then go back to operating properly?
If it was turning over the whole time, it probably started on Monday because the plugs and engine dried out, but the compression loss/return doesn't make sense to me.
Can anyone figure out what happened?
-Pete
Old Jun 23, 2003 | 03:14 PM
wicky's Avatar
wet plugs? I don't understand how you can have no compression and then the car runs fine? strange.
EDIT** glad you don't need a new motor BTW
Old Jun 23, 2003 | 04:02 PM
jeffbrig's Avatar
I've seen a valve stick open before, but it was on an old Ford pushrod engine in my father's boat. We were able to get it going again, but it was always problematic. That engine was in pretty bad shape, he pulled the head and had new valves within six months. In other words, it didn't magically 'fix' itself just because it unstuck one day. Someting causes the valve to stick (is the valve slightly bent/dinged?) and this may not be the last you see of it.
bkinpa
Apr 21, 2012 12:18 PM
myslows2k
Nov 12, 2009 06:19 PM
Elroy303
13
Nov 15, 2004 11:37 AM
Voodoo_S2K
Mar 1, 2004 09:25 AM
Tireguy
Dec 21, 2002 09:18 AM
