Hydrolocking On Cai
Originally posted by DouglaS2000
Welp, simple solution.. create a shield around the top of the filter element to deflect the water away from the filter..
It should be an easy thing to fix.
Drill a small hole at the lowest point of the CAI so water can get out.
On the outside of the intake make a square flap that covers the hole but with only 3 edges tape/seal to the intake. The fourth one is free.
Water will drain out when the engine is off.
With negative pressure, when the NA enginine runs, the flap will close onto and seal the hole.
This is the basis of a hymen flap that you normally see in hospital for pneumothorax and is also the treatment for open chest wound. I think it will work for the F20C.
I was going to do this earlier but I hope that my engine will survive until the Vortech come.
If you plug that hole then water goes into the next hole. That hole drains to on top of the headlight. I dunno if its good to have a constant water flow on a rainy day to the back of the headlight?
The drain placement is usually there for a reason.
