Hydrolocking On Cai
Old Jun 22, 2003 | 08:34 PM
4IGS2000's Avatar
Spammer
Pictures are worth 1000 words!
https://www.s2ki.com/forums/showthread.php?...threadid=130727
Old Jun 22, 2003 | 08:56 PM
wicky's Avatar
that is priceless info for our cars. Thank you. Pictures ARE worth 1000 words........
Old Jun 23, 2003 | 12:05 AM
DouglaS2000's Avatar
Welp, simple solution.. create a shield around the top of the filter element to deflect the water away from the filter..
Old Jun 23, 2003 | 12:48 AM
4IGS2000's Avatar
Spammer
was thinking of doing it, but space seems very limited, if the shroud is too tight around the filter it will affect air flow. I will have to back to the drawing board on this one
Old Jun 23, 2003 | 02:12 AM
honda9krpm's Avatar
It should be an easy thing to fix.
Drill a small hole at the lowest point of the CAI so water can get out.
On the outside of the intake make a square flap that covers the hole but with only 3 edges tape/seal to the intake. The fourth one is free.
Water will drain out when the engine is off.
With negative pressure, when the NA enginine runs, the flap will close onto and seal the hole.
This is the basis of a hymen flap that you normally see in hospital for pneumothorax and is also the treatment for open chest wound. I think it will work for the F20C.
I was going to do this earlier but I hope that my engine will survive until the Vortech come.
Old Jun 23, 2003 | 08:58 AM
DJ Qube's Avatar
[QUOTE]Originally posted by honda9krpm
[B]This is the basis of a hymen flap that you normally see in hospital for pneumothorax and is also the treatment for open chest wound.
Old Jun 23, 2003 | 09:02 AM
God's Avatar
God
How about a piece of tape over that hole?
A little tape might not prevent coat hanger penetration but surely it will stop some rain water.
Old Jun 23, 2003 | 09:06 AM
wicky's Avatar
I was thinking a rubber plug would do the trick.
Old Jun 23, 2003 | 09:46 AM
JDMwhore's Avatar
If you plug that hole then water goes into the next hole. That hole drains to on top of the headlight. I dunno if its good to have a constant water flow on a rainy day to the back of the headlight? The drain placement is usually there for a reason.
Old Jun 23, 2003 | 09:53 AM
wicky's Avatar
good points. But the headlight is sealed and I'd rather take my chances with the headlight than the engine
