HyperGround Wires
Old Jun 2, 2003 | 04:01 PM
HTownScene's Avatar
Default HyperGround Wires
Has anyone tried or even heard of Hyper Ground Wires? I heard from a couple of people that it actually increase a few hp and tq. I want to try it out but I dont know if anyone had any experience with it. Please post your comments.
Old Jun 2, 2003 | 05:12 PM
TwoFourty's Avatar
There have been several large discussions about such kits. It has been proven in the past that these kits work on some cars. However, I don't believe anyone has ever definitively proved or disproved that they work on the S. I was considering doing a similar mod myself, but I don't think the S is poorly grounded and you might gain 1 or 2 horsepower if any. You do have to be careful when installing the grounds, I would suggest when you attach the ground to the head that you do so away from the distributor. If you don't you could actually decrease horsepower and torque. It would be nice to get some actual results proving or disproving that this type of mod works on the S.
Old Jun 2, 2003 | 08:02 PM
MacGyver's Avatar
See my comments here...
https://www.s2ki.com/forums/showthread.php?...?threadid=92377
..then lock this thread up tight afterwards.
Old Jun 2, 2003 | 08:12 PM
speeeding's Avatar
Pivot carries a "super earth" ground system, but it hasn't been dyno'ed yet.
Old Jun 2, 2003 | 09:10 PM
allkingz's Avatar
The analogy that has been used before is that adding a "hyper ground" system is no different than changing your spark plugs or oil. There shouldn't be any real noticeable gains unless there was an existing problem, ie. corrosion.
About 6 months ago, I replaced the 8 gauge factory ground cables on my 00 Si with 4 gauge Monster cable that I've had laying around to see if I could notice a difference. There was no noticeable difference.
Definitely check out MacGyver's thread... and like he said, lets put this all to rest.
Brownsound
Feb 27, 2008 01:09 PM
izzysand
South Florida
Jun 4, 2007 10:04 AM
dp2580
May 20, 2003 04:42 AM
Shamu
May 17, 2003 04:39 PM
SKREEMR
Dec 28, 2002 04:16 PM
