I can only start using the "engine start button"
Old Oct 27, 2012 | 04:37 PM
Bloody Hatch's Avatar
Default I can only start using the "engine start button"
Engine start button seems to be my only method of turning the car over. It won't let me turn over using the key. When the key is in, dash lights up, EPS light stays on but when it turns over, EPS light is off and stays off. But I can't turn it over with the key, kind of like being blocked from the III position. Any ideas. New to the S2000.
Old Oct 27, 2012 | 04:39 PM
RacerXI's Avatar
That's how it works. The key turns to the II position and you push the button.
Old Oct 27, 2012 | 04:40 PM
MM3Kwolik's Avatar
This cannot be a serious question.....
Old Oct 27, 2012 | 04:50 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Old Oct 27, 2012 | 05:03 PM
Didn't know. This is my first engine button type car. I've been used to driving a DX model.
Old Oct 27, 2012 | 05:25 PM
ed-gsxr's Avatar
i had a good laugh about it hahahaha
Old Oct 27, 2012 | 05:47 PM
FISH22's Avatar
You're not turning the key hard enough.
Kidding.
Old Oct 27, 2012 | 05:58 PM
sillyboybmxer's Avatar
the s2000 is unique in this way.....out of the thousands of cars i have drove, i believe this to be one of the only ones that you have to turn a key and then press a button.
Old Oct 27, 2012 | 05:59 PM
ruut's Avatar
Hmmmm! Sounds like a dealer issue. Something to do with the fusebox and a relay. The fetzer diode if I remember right. I would have it towed driving it could be bad.
Good Luck!
Old Oct 27, 2012 | 08:45 PM
xviper's Avatar
Have you tried a 4 foot breaker bar on the key? I hear it needs quite a bit of torque to turn it to the cranking position.
