i need help please..
Old Mar 25, 2008 | 10:25 PM
JHooby's Avatar
Default i need help please..
i just installed a 04 oem used clutch(15k miles) on MY01.
when i got the car back, i noticed a nasty sound coming from the tranny while decelerating at 4000 rpms. it does it the most in 2nd gear
the sound is like.. a rattleing noise. when in idle or on the throttle, the noise isnt there.
only when decelerating at 4000 rpms.
what could this be???
thanks guys, its really bothering me.
Old Mar 25, 2008 | 11:00 PM
JHooby's Avatar
bumpp..
Old Mar 26, 2008 | 03:13 AM
RedY2KS2k's Avatar
Search for TSB054
Old Mar 26, 2008 | 03:32 AM
Rollinx25's Avatar
Possible throw out bearing. Did you replace it when you replaced the clutch?
Old Mar 26, 2008 | 04:02 AM
litre-eater's Avatar
the dreaded clutch buzz.....its annoying but won't hurt the car. the springs in the clutch disc reach their resonance frequency and start to buzz on decel. My car does the same thing.
Old Mar 26, 2008 | 03:27 PM
JHooby's Avatar
no i didnt.. if it is the throw out bearing is it possible the sound will come from the tranny not clutch ?
its a chattering noise..
Old Mar 26, 2008 | 05:22 PM
Slows2k's Avatar
You sure the used clutch came from a 04?
My guess is it came from a 00-01
Old Mar 26, 2008 | 08:09 PM
RedY2KS2k's Avatar
Sure sounds like it to me...
And I do know a thing or two about the TSB054 clutch buzz: mine was so bad I got no pleasure out of ownership. However, I'm happy to report that replacing the disk fixed the problem, and the car is enjoyable again. $125 or so, a couple of evenings watching ball games in the garage, and it's all good.
Old Mar 26, 2008 | 11:29 PM
JHooby's Avatar
i HAD the 00-01 clutch buzz on my first OEM clutch.
this is an 04 clutch and the chattering is coming from the TRANSMISSION not the clutch. it is not a buzz.
Old Mar 27, 2008 | 09:19 AM
RedY2KS2k's Avatar
Sounds like you're going to spend another couple of evenings under the car... Hope it's not expensive. Good luck.
