I need some help
Old Feb 2, 2011 | 02:12 PM
s2k16803's Avatar
Default I need some help
Hey guys I need some help I have a freshly built motor, I went to start it last week and it wouldn't start but was trying(a cylinder would fire randomly), we pulled the spark plugs and coolant was in all 4 cylinders. We pulled the intake pipe and there is coolant in the intake manifold. I thought it was the intake manifold gasket so instead of stock I went with the hondata heatshield intake mani gasket and installed it last night. We went to start it today and it fired up then died in about 5 seconds, so I pulled the plugs and sure enough there is coolant in all 4 cylinders. As of now Im hoping its not the headgasket. If you have any knowledge on the subject I would really appreciate some help.
Thanks guys,
Jordan
Old Feb 2, 2011 | 02:23 PM
s2k16803's Avatar
also wanted to add there is more coolant in the intake manifold than in the cylinders
Old Feb 2, 2011 | 09:53 PM
s2cho's Avatar
oooooo did you silicone the gaskets?
i think thats your problem, and what did you torque it too?
Old Feb 3, 2011 | 04:23 AM
bpaspi's Avatar
first of all you should make a leak test on your cooling system.
Old Feb 3, 2011 | 04:44 AM
chris_barry's Avatar
check also that you havent mixed up some of the vacuum and water lines around the inlet manifold.
Old Feb 3, 2011 | 05:25 AM
rh76's Avatar
Look in here... Billman250 posted a photo of what chris barry is talking about.
https://www.s2ki.com/forums/index.php?showtopic=844170
Old Feb 3, 2011 | 05:28 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You definitely have the two lines crossed. One is vac, one is coolant. check link above.
Old Feb 3, 2011 | 08:16 AM
s2k16803's Avatar
thanks for all the input guys I will check those two lines today but I just want to say billman250 you deserve a nobel peace prize with how much you help everyone out on this site, your the man!
Old Feb 3, 2011 | 08:20 AM
blobianco's Avatar
Yes i would also think it would be silicon or lines!
Old Feb 3, 2011 | 08:57 AM
bpaspi's Avatar
Silicon? That stuff from the named valley?
