I think I found the problem (tranny popping out of gear)
Old Apr 8, 2017 | 06:38 AM
st.ryder64's Avatar
Default I think I found the problem (tranny popping out of gear)
In the last week my tranny popped out of sixth and fourth a couple times. Fearing the worst, I did my due diligence and googled the crap out of it, ending up buying new tranny fluid with intent to change it today. When I got under there, I discovered that the fill plug is....missing. So there's probably not much, in any fluid in there.
1. What kind of damage might I have done to the tranny?
2. Need to replace the plug/washer. Any idea what thread pitch it is? Manuals looks like it's 14mm diameter.
Thanks in advance.
Old Apr 8, 2017 | 06:52 AM
jst2878's Avatar
Yikes. Fix that. Also, look at your motor and transmission mounts. They might be toast too
Old Apr 8, 2017 | 07:06 AM
cdelena's Avatar
In the cases I am aware of the failure to stay in gear is an internal shaft problem and is fixed with a transmission repair. I would be surprised that a fluid change or external change would have much affect.
Old Apr 8, 2017 | 07:53 AM
st.ryder64's Avatar
How about if there's only about a cup of tranny fluid? Cuz that's what came out when I drained it.
Old Apr 8, 2017 | 07:17 PM
RacerZook's Avatar
Never tore down an s2k trans, but a broken syncro spring would cause it to pop out of gear. A $5 part. But in your situation, i would be ready to replace all the bearings as well.
Old Apr 8, 2017 | 10:53 PM
Singh_snisen's Avatar
Running almost dry is bad. Depends also how much u drove on it empty. If I wer u I would refill oil and drive cautiously until u don't hear any weird noises. If anything u prob toasted some of the bearings. Iv done my trans.... is easy and cheap to do but labor intensive.
paul2011s2000
Mar 11, 2012 09:44 AM
darkwatch
Apr 29, 2008 06:50 PM
CourageOO7
Jun 24, 2006 07:36 AM
p0pe
Jun 11, 2006 04:25 PM
tesseract
Mar 27, 2004 02:37 PM
