ideling /window issues!
i really need some questions answered please, i will make a long story short
changed oil, pulled out v-tec solenoid to do filter. Forgot to plug it back in when started car because check engine light was on. Figured it out and plugged the solenoid back in check engine light is still on. Had advice to unplug the ecu and plug it back in which worked every well. Engine light turned off was thrilled!
1) Now my passenger side window does not work. is it because of me unplugging some connections? i checked the fuses and non are burt. Can it be the window motor?
after oil change the idling boggles down all the way to the last bar and i have read that cleaning the idle air control valve would solve the problem
2)can anyone show a picture of that idle air control valve please
because i am still clueless after reading the other posts
sorry for the dumb questions but i just want to understand this as much as possible
where is that? are you talking about the window lock? from driver side or passenger side the window will not go up
dillehay
Dec 21, 2001 08:05 PM
