Idle
Old Mar 8, 2014 | 08:19 AM
PaGEmaZt3r's Avatar
Originally Posted by s2000maniac
I just bought a brand new IAC valve coz I had the old one cleaned and it kind of fixed the issues but it came back. You can buy the IAC from Advance Auto for like 100. Buy the one that says "wells electronics" it's actually made in Japan by DENSO. Also it comes with a lifetime warranty. You can use the "TRT30" coupon for 30% off. Also replace those coolant hoses that go into the IAC valve coz once you take them out, the seal breaks and it they will start leaking coolant under pressure. I think if you had bad valves you would probably get misfire at idle. Good Luck!
Thanks for the info! Glad I didn't order one yet! And I forgot a huge detail. My car did pop a cel at idle for a misfire on all 4 cylinders. I just assumed it was coil packs and replaced them all. Has not came back on yet.. Unless that wasn't the real problem.
Old Mar 8, 2014 | 08:23 AM
PaGEmaZt3r's Avatar
Originally Posted by Billman250
I dont think I have a diy on iac valve. How did you clean it?
I removed it ad used a combination of q-tips and carb cleaner inside the outer chambers. The middle chamber I flooded with carb cleaner and lightly spun the valve. There was a decent amount of drag and it would catch every few spins. I proceeded to do spin it (more of a light flick) until it got better. Still felt a bit of a "catch" every few spins.
Old Mar 8, 2014 | 08:33 AM
PaGEmaZt3r's Avatar
Originally Posted by MR.T
What work had you done since your first post? You might want to go into detail concerning the popping noise.... Maybe video.
Since my last post I went out to continue fiddling with the car. I started it and followed the coolant bleed DIY because when I rebuilt the engine and added coolant I did not bleed it. I thought maybe of some reason this would cause it. However there was no air in the system. Next I started to hear a kind of popping noise like popping a lid of a can but really fast. I thought maybe it was air leaking somewhere so I started searching for an vacuum leak. I couldn't find a leaky hose so I put a ratchet to the intake bolts to see if one came loose. The plug to the IAC valve was in the way so I removed it. (The car was off key on)
Old Mar 20, 2014 | 09:59 AM
PaGEmaZt3r's Avatar
Still haven't solved this.
Old Mar 21, 2014 | 09:04 AM
MR.T's Avatar
Still have low idle/stumble you mean? Is the popping noise still there?
Old Apr 2, 2014 | 11:58 AM
PaGEmaZt3r's Avatar
I bought new coil packs and got rid of the popping noise. My low idle issue is still there.
gptoyz
Jun 4, 2021 02:55 PM
Canadian_CD9A
Nov 28, 2017 04:29 PM
goravens
Oct 29, 2013 06:58 AM
scotty2k2
Aug 26, 2012 09:32 AM
114_ap2
Dec 9, 2007 02:04 PM
