idle
Old Aug 25, 2012 | 05:35 AM
scotty2k2's Avatar
Default idle
i have this minor problem where my idle will drop below 500 and almost to the point where the engine comes close to turning itself off, either when coming to a stop or when A/C is running on high and coming to a stop. then the idle will return to normal levels. Honda says it may be a valve issue. anyone have any ideas?
Old Aug 25, 2012 | 07:19 AM
franky's Avatar
have u disconnect your battery before that started happening? if so, that just means u have to do the ecu relearn procedure.
Old Aug 25, 2012 | 07:24 AM
s2knoob89's Avatar
Try cleaning the IACV.
Old Aug 25, 2012 | 07:25 AM
scotty2k2's Avatar
i replaced the battery in April, and the problem still existed. so i took it in to Honda this last week and they did the idle relearn but it is still doing it and they can't find a problem short of tearing the engine down. they said it may be a valve that is getting stuck? is there anything that i can add to the fuel to help clean the valves?
Old Aug 25, 2012 | 09:32 AM
ed-gsxr's Avatar
do what s2knoob89 suggested. clean the iac valve.
DIY clean iacv
Old Aug 25, 2012 | 07:17 PM
4forall's Avatar
This question seems to get asked a least once every 48 hours. Makes you wonder why honda couldnt just make a better idling system than iacv and what not. i mean its astronomical the number of times i've read posts like this. seems every s2k goes through this at some point and it never seems to get fixed all the way.
1. clean iacv
2. map whack
3. clean throttle body
4. idle relearn
5. pcv valve
6. injector cleaner
7. valve adjustment
8. throttle cable adjustment
9. vacuum leak check
This list goes on and on. Its almost like after so many years/miles the stock ecu just cant cope with idling the motor. Frustrating. I wanna go to the dealership and test drive a newer one just to feel it idle right again lol.
Old Aug 26, 2012 | 08:03 AM
_brandon's Avatar
Do you have a lightweight flywheel? Mine does the same thing and thats what I always assumed it was.. Ofcourse my valvetrain is noisey as hell so you have me a bit worried
Old Aug 26, 2012 | 09:32 AM
scotty2k2's Avatar
No i don't have a lightweight flywheel, i have left everything stock on it. not sure about your drivetrain though. i'm far from a techie when it comes to cars and engines.
Myles Chandler
Apr 3, 2019 11:12 PM
Saad_Z
Jun 22, 2013 09:47 AM
Bkclark
Jul 30, 2012 04:46 PM
114_ap2
Dec 9, 2007 02:04 PM
s2000guy
Jan 2, 2004 03:27 AM
