idle goes down like engine id going to die...
hi guys is it normal that when you drvie normaly and you remove your pedal on thhe gas your engine goes dowm up to 600plus rpm and your oil pressure goes down up to 38psi then suddenly right after going down it goes up to 800-900plus rpm thats 49-50ps and maintains the 800-900lus rpm and 49-50psi oil presure is this normal or is my throtle body dirty already?? or my sensors... it feels like that the engine is going to die when ou release your foot on the gas pedal..... most specialy with the aircon off.... pls help me guys! thanks so much!
Might also be a good time to as you had said, clean out your throttle body (especially if you find it dirty or have a sticky throttle valve)
Originally Posted by pinoyk20,Apr 7 2008, 06:41 AM
oh how do you do it??? thanks!
Fuse can be found behind the fuse cover inside the footwell:
Or remove the negative battery terminal and wait for 10 mins
Copied from s2kuk faq
Japmuscle
Jul 22, 2015 12:53 AM
Luder94
Sep 6, 2001 06:12 PM
