Idle issue (cannot narrow down the cause)
Old Nov 14, 2018 | 09:20 AM
oliversok's Avatar
Default Idle issue (cannot narrow down the cause)
So I have been having idle issues come up again recently where when i depress the clutch pedal while the car is in motion the idle will hover at around 2k rpms and will continue to stay there until completely stopped where it will fall back to normal range. Also the car will rev up and down on cold start ups at times on its own. I have replaced coil packs, spark plugs, Iacv valve, throttle body, map sensor, spark plug seals and did ecu re-learn procedure. What are your guy’s input. The car is MY2000 with 170k miles
Old Nov 14, 2018 | 09:57 AM
windhund116's Avatar
Vacuum leak?
Old Nov 14, 2018 | 10:55 AM
waino's Avatar
My thought too. Take your propane torch and flow a little propane around parts of the engine. When the idle speed climbs, you've found your leak.
Old Nov 14, 2018 | 12:11 PM
engifineer's Avatar
Originally Posted by waino
My thought too. Take your UNLIT! propane torch and flow a little propane around parts of the engine. When the idle speed climbs, you've found your leak.
Added an edit there .. but you likely know that lol
Old Nov 14, 2018 | 12:36 PM
oliversok's Avatar
Thank you for all the help. Do you know where the leaks are commonly found in these types of cases?
Old Nov 14, 2018 | 12:59 PM
engifineer's Avatar
There are two vac lines connected to a molded metal connector near the front of the valve cover that are super easy to miss, but those cause the air pump not to run and a CEL after some amount of time in my experience, so probably not it. But I knocked one off when removing the valve cover once and did not notice until I started the car.
I do not know of any other "typical" ones on this car really.
Old Nov 14, 2018 | 02:26 PM
oliversok's Avatar
Thanks for that. They were disconnected, but it may not be the cause for the idle problems i am experiencing. I will try the butane approach. Thanks
Old Nov 14, 2018 | 02:41 PM
noodels's Avatar
>>>>>>>>>>>>>>>>>>>>>>UNLIT...……………… ..
Old Nov 14, 2018 | 03:42 PM
I suppose LIT or UNLIT, depends on how much you like the car. Or how much pain it has given you.
Soapy water, sprayed from spray bottle maybe less hazardous? Looks for bubbles, associated with vacuum leak.
Old Nov 14, 2018 | 06:10 PM
oliversok's Avatar
Lol. Yea at first I pictured a lit torch going over the engine.
