Idle issue (cannot narrow down the cause)
If you spray that onto vacuum leak, you will pull soapy water into your intake manifold. Vacuum leaks suck air into the engine.
The brake booster hose? Other places that could cause a vacuum leak besides IACV? Throttle body gasket, IM gasket, Injector seals, oil cap? Unless the TB or IM have been previously removed we can eliminate those as sources on an otherwise stock car. That only leaves the injectors, IACV,. oil cap or booster hose.
toycar8
Mar 18, 2004 10:21 AM
