Idle issues with A/C and (or) headlights on!
Old Jul 8, 2008 | 06:50 PM
BAMbam160's Avatar
Default Idle issues with A/C and (or) headlights on!
Hello all,
All and all my cars runs great. but, recently it started this strange idle problem. It seems that once the compressor kicks on the rpms drop form 12-1300 to 6-700. (according to the VAFC) Sometimes the car will begin to "buck" really bad until I turn the A/C off, than all is well again. I know what you're thinking, "Then just don't use the A/C." but, I live in GA and it gets hot as hell here in the summer. Having some cool air sometimes is rather important. The other time I noticed a significant drop in rpms is when the headlights come on. I have checked the grounds and they seem free of corrotion and tight. I recently replaced the MAF and I have cleaned the IAC less than 3k miles ago. Any one else experience this? Any help would be greatly appreciated.
Thanks, Keith
Old Jul 8, 2008 | 06:54 PM
RedY2KS2k's Avatar
Thanks, Keith
What kind of car is this?
Old Jul 8, 2008 | 06:59 PM
skeithr's Avatar
im no expert but 1200-1300 seems a little high for normal idle anyway. is it a cold start when this happens, also when you say buck, what do you mean excactly, when i turn on either the ac or the lights at idle, my cars rpms will drop maybe 200 or so but a couple of seconds later it is back to normal
Old Jul 8, 2008 | 07:44 PM
BAMbam160's Avatar
An S2000, My apologies for the typo . I meant my MAP sensor. As in I've replaced it after getting a CEL, after the "whack" not doing any good.
By "buck" I mean a very irratic acceleration surge from an even application of the throttle. The car feels like you're feathering the throttle on and off when all I'm doing is giving it normal amount of gas to accelerate. Once you turn off the A/C the car operates normally.
Any Ideas?
Old Jul 9, 2008 | 05:54 AM
BAMbam160's Avatar
Anyone?
Old Jul 9, 2008 | 05:24 PM
BAMbam160's Avatar
Is this thing on?
Old Jul 9, 2008 | 05:32 PM
9kFever's Avatar
12-1300 is high. 800-1000 is normal
Old Jul 10, 2008 | 06:12 AM
iDomN8U's Avatar
check the IAC lines again to make sure you don't have a leak, move on to the eletrical side (battery, alternator)
First though, allow the ecu to adapt.
Old Jul 10, 2008 | 07:58 AM
HankookS2K's Avatar
sounds like battery or alternator if it happens with your headlights as well.
EK9MAX
Jun 29, 2010 07:32 AM
bjl
Nov 6, 2009 10:49 AM
BAMbam160
Jul 9, 2008 10:40 PM
x s2k x
Nov 15, 2005 02:24 PM
WtbS2k
Nov 14, 2004 06:13 PM
