Idle problem
Old Nov 27, 2015 | 12:25 PM
Vegale's Avatar
Default Idle problem
Hi Im new here and maybe some wrote about problem when the car is on idle specially with the a/c turned on, I allready change the idle valve and nothing happen I will apreciate your help thanks
Luis
Old Nov 29, 2015 | 08:51 PM
dsthez's Avatar
What's the problem your having now?
Old Nov 30, 2015 | 04:06 PM
Vegale's Avatar
With the air conditioning turned on and the car on stop the rpm go down almost died but only with a/c on.
Old Nov 30, 2015 | 04:23 PM
Soviet's Avatar
If you have already cleaned your IACV and did an idle relearn then perhaps there is an extremely high resistance on your AC pulley... This would indicate that the pulley may need to be replaced or that the AC compressor would need to be replaced. If there is resistance inside the AC compressor I'm guessing your AC clutch will be toast soon...
Just thinking out loud here...
What happens if you run the car with the serpentine belt off and turn on the AC? I'm hoping that nothing would happen, which would indicate a problem with the AC compressor.
You can pull off the serpentine belt with a 14mm socket in about 1 minute.
Old Nov 30, 2015 | 04:33 PM
dsthez's Avatar
Good man soviet
Old Nov 30, 2015 | 04:38 PM
Soviet's Avatar
Originally Posted by dsthez
Good man soviet
Old Dec 2, 2015 | 02:08 AM
Vegale's Avatar
Thanks Soviet I will see that and let you know
liybzd
May 13, 2014 08:40 AM
Amer
Aug 15, 2009 12:15 PM
Azbola
Jul 6, 2009 10:44 AM
toecheese
Sep 20, 2007 07:31 PM
krazik
Mar 15, 2003 05:16 PM
