Idle Problems
Old Nov 14, 2006 | 07:12 PM
UniqueS2k's Avatar
Angry Idle Problems
I have Idle problems when ever i come to a stop sign and the car sometimes dies. I was wondering what can be the result of having idle problems? o2sensor, vacum leak, or what?
Old Nov 15, 2006 | 12:45 AM
SIIK2NR's Avatar
Couple of things to consider:
Map sensor whack might be needed.
Possible change in weather heat/cold.
Adjust throttle cable.
Tim
Old Nov 15, 2006 | 01:45 AM
donger274's Avatar
maybe something in your gas?
Old Nov 15, 2006 | 07:13 AM
Soul Coughing's Avatar
from reading the other threads recently... maybe you bent a valve?
Old Nov 15, 2006 | 08:21 AM
djpeak10's Avatar
Do not adjust the throttle cabel that is the job of the IAC.
Your IAC needs to be cleaned first off. I am willing to bet it is really dirty and causing your rough idle. If need be I will explain the process.
Old Nov 15, 2006 | 01:30 PM
Sniper_S2K's Avatar
Just do an ECU reset and go though the idle learn procedure see if that helps.
Sniper.
Old Nov 15, 2006 | 04:22 PM
modifry's Avatar
Honorary Member
If it also idles rough and you have erratic off-idle acceleration - map whack. Otherwise, I'd lean towards the IAC.
Old Nov 15, 2006 | 05:05 PM
jeggy's Avatar
https://www.s2ki.com/forums/index.php?showtopic=386868
read it then go from there.
Old Nov 15, 2006 | 05:06 PM
myculito's Avatar
I think it might be important to ask whether or not you have any mods on the car.
Are you using anything other than the OEM intake system?
Old Nov 15, 2006 | 07:51 PM
UniqueS2k's Avatar
What is IAC? And how can i fix that?
