Idle speed question- ICV
Old Dec 14, 2007 | 12:43 PM
acematteo's Avatar
Default Idle speed question- ICV
Does anyone have a step by step for removing and cleaning the ICV? I think it is the reason why my cars idle will not remain stable. My idle wants to remain around 3K or stall. If I hit the gas too hard and fast, it will drop so low that it will stall. If I am light and gentle on the throttle, it will raise to 3k; even if I did not bring the RPMs that high. Has anyone experienced this problem? If so, WHAT IS IT? I am so done with this. Oh, I forgot, this started after I replaced the intake with a cold air fugita f5 intake (pimp). Any info will help-THX
Old Dec 14, 2007 | 08:36 PM
SenderGreen's Avatar
Try searching "IAC" Idle Air Control Valve. Also if you just switched your intake, your ECU may still be trying to learn/compensate. Good Luck.
https://www.s2ki.com/forums/index.php?showt...post&p=10625665
Bliss
Apr 9, 2020 10:36 AM
ryry668
Sep 8, 2013 08:23 PM
iRkennethMe
13
Mar 3, 2009 09:12 PM
Carwyn
Jan 7, 2009 11:48 AM
REvan
Apr 22, 2006 05:47 PM
