Idle Still Stumbles
Old Aug 12, 2013 | 07:00 AM
super_mut's Avatar
Default Idle Still Stumbles
Hey Guys,
I wanted to get your opinion on what my next plan of action is. My idle is still stumbling a bit when I am revving the car and letting it go back to idle. I've already done the following:
1) Clean out the IAC valve
2) MAP wack
3) Valve adjustment
After the valve adjustment this weekend I feel that it is a bit better. It doesn't stumble as often nor does it seem to stumble to almost stalling out. Should I just replace the MAP sensor at this point?
MY: 2001
Miles: 80K
Old Aug 13, 2013 | 06:29 AM
super_mut's Avatar
bUMP
Old Aug 13, 2013 | 09:04 AM
EnvyMyS2K's Avatar
When I had this problem it was an aftermarket TPS causing it. I just replaced my throttle body with one that had an OEM TPS and it idles perfect with no vibrations/shivers now.
Old Aug 14, 2013 | 04:19 AM
iamxpl's Avatar
just addressed one of these problems on a friends 05. we cleaned the IAC, MAP and air filter. check your spark plugs. i had to change his spark plug seals since they were severly worn out and disfigured and oil was getting through.
Old Aug 16, 2013 | 10:46 PM
super_mut's Avatar
Haven't heard of the TPS being jacked.
I recently changed my plugs.
So now it's a toss up between the TPS and the MAP...
Old Aug 17, 2013 | 06:54 AM
EnvyMyS2K's Avatar
Is your TPS pointed towards the floor or upwards?
Old Aug 18, 2013 | 11:35 AM
AZ-S2000's Avatar
Zip tie the MAP to make sure the connection is good, than do a ECU reset, and check back. I had stalling/bad idle issue and I did this and no more.
Old Aug 18, 2013 | 02:55 PM
super_mut's Avatar
My TPS is pointed upwards.
I did this already, sadly it didn't do very much.
Old Aug 19, 2013 | 05:38 AM
iamxpl's Avatar
check your throttle cable adjustment. if there is more than 1/4 on an inch deflection try adjusting it. There is also an adjustment screw for the TPS. take off your intake clean the TB.
adjust your cables!
Old Aug 19, 2013 | 07:11 AM
super_mut's Avatar
adjust your cables!
I have trouble believing it would be slack in the pedal.
