Idling low (shake feeling like engine stalling)
Here's the scenario:
Had CEL because of misfiring p301-p304
Replaced spark plugs but CEL came back
Did valve adjustment (Honda said they were tighter than specs) CEL gone but came back
Honda replaced ignition coils under emission warranty, CEL gone but few days later when I tap the gas the rpm drops to 200-300 rpms and the engine shakes like its going to stall but it goes back up to normal idle 600-800 rpms.
I don't have a CEL and when I used OBD2 scanner it found no codes.
Anyone experience this? Thanks.
Originally Posted by Ghost,Feb 19 2006, 10:00 PM
I had the same problem about a year ago. For some reason it was the Battery.. just bought a new one and the problem ended. Also the battery i replaced was 3+ years old.
Originally Posted by Wisconsin S2k,Feb 20 2006, 07:41 AM
This is likely just coincidence with your coil pack change. Just about every S2000 does this at one point or another. Mine does it several times a year at least. It's in large part due to temp or humidity changes. The ECU just gets "confused". This should go away within a few days. If it doesn't, then post back here and there could be something greater going on.
Maybe try a fuel injector cleaner? I just put in some of the techron fuel cleaner from Costco. It may be conicidence, but I havent gotten the low idle shakes to come back yet.
Plus the engine seems to rev more smoothly. I think I'll be putting in a bottle of this stuff in the fuel tank with every oil change.
Originally Posted by Amer,Feb 21 2006, 10:40 PM
I just had my 7500 mile maintenance and I believe they put fuel injector cleaner. But it still randomly idles low to a point it shakes for about a second.
He said it was very common and a common complaint thats easily fixed.
