Idling problem
Old Apr 12, 2017 | 08:03 AM
Gavin1274's Avatar
Default Idling problem
I have a 2002 s2000, recently it has been acting up with very low idle at stop sometimes and slow rpm back down to idle problems as well as when barely pushing on gas feels like car is getting no gas and when in low gears will start to hesitate and "jump" I guess you could say, I have replaced MAP sensor and cleaned idle control valve. I have heard it could be bad or failing cat, what do you guys think it could be? Thank you
Old Apr 12, 2017 | 10:08 AM
Car Analogy's Avatar
There is a very specific process for cleaning the iacv on these cars. Did you follow that process, or just spray some cleaner in it and called it good? Search for cleaning diy, follow it, then report back.
Also sounds like vacuum leak symptoms. Check pcv valve. Look for leaking vacuum hoses. Look for leak around IM to block and TB to IM.
Old Apr 12, 2017 | 11:08 AM
ok2k's Avatar
Spending $100 and 10 minutes to replace the iacv w/ a new one brought the car back to life from similar symptoms.
Old Apr 12, 2017 | 12:38 PM
Gavin1274's Avatar
even the gassing it when in a low gear, going through a parking lot dor say and it seeming like it is not receiving gas and hesitating/jerking feel?
Old Apr 12, 2017 | 12:39 PM
Gavin1274's Avatar
all vacuum lines seem good, and i followed a video on cleaning it so im pretty sure i did it right.
chicomacattack
Jan 27, 2015 03:30 PM
clio
Dec 5, 2014 05:30 PM
brooklyns2k
Nov 28, 2012 12:09 PM
clarkster009
May 28, 2009 09:28 AM
UniqueS2k
Nov 16, 2006 06:21 AM
