Ignition Coils - repair or replace
Old 01-28-2019, 05:51 AM
VM00's Avatar
Default Ignition Coils - repair or replace
Last weekend, I have attempted to change spark plugs on '05 AP2, 110K miles. I could not get them out easily, so sprayed some PB Blaster and left overnight.
After pulling out the ignition coils the next day, I realized that 3 of the 4 bushings separated from the coil. It must have been the PB Blaster that ate away the glue that was holding them.
Can I superglue them back and reuse, or is it too risky, considering they could get stuck on the spark plug end?
If I need to buy new ones, which brand?
Old 01-28-2019, 06:19 AM
cgarrett23's Avatar
At 110k, I'd replace them if they are falling apart. Denso are the OEM's, they are not cheap.
Old 01-28-2019, 06:21 AM
windhund116's Avatar
Received 1,441 Likes on 966 Posts
Just off-hand, I would not use super glue. Does there appear to be any damage to the rest of each coil pack?
Old 01-28-2019, 06:35 AM
VM00's Avatar
No other damage that I can see.
Old 01-28-2019, 06:51 AM
s2000ellier's Avatar
Just replace them.
Amazon Amazon
if you have Prime, buy here.
Old 01-28-2019, 12:47 PM
Mr.Matchbox's Avatar
You could try to glue it with heat-resistent Silicone = Engine sealant.
Or buy replacements...
Old 01-28-2019, 02:55 PM
HarryD's Avatar
The big question is, what happens if whatever glue you put causes them to fail. The caps look about the right height that they'll stick on top of your spark plugs, so it'll be a PITA (although not impossible) to fish them out.
I'd personally buy new ones. Some Autozones have "Made in Japan/Denso" coil packs for MY00-05 for $58.99 branded as Denso (obviously) or for $48.99 branded as Duralast (but look for the made in Japan/Denso sticker -- it's a must -- not all of them have it) that are exactly the same. FYI.
Or just Amazon it per the other guy.
Old 01-28-2019, 03:19 PM
AP1Chief's Avatar
Get K series coils.
Old 01-29-2019, 10:56 AM
soulicious's Avatar
https://www.s2ki.com/forums/s2000-fo...-819031/page1/
Old 01-29-2019, 10:58 AM
Billman250's Avatar
Received 1,271 Likes on 775 Posts
Those end caps coming off is common. Provided its not torn, you can silicone in back on.
Quick Reply: Ignition Coils - repair or replace
