Ignition switch discontinued help
bad ignition switch and was hoping to buy a replacement but it is discontinued and no one sells one anywhere for a 05. Does anyone know if there is an ignition switch from a different vehicle I can use instead.
I thought all 2005s were AP2s. If it has the F22C, should work? Even if it didn't have an F22C, I'd be surprised if an ignition switch (which should just be connecting + and - on press) wouldn't work on an F20C.
Do you need the switch or the entire lock assembly? I didn't see just the switch as a separate part. I think it gets complicated with the chip in the key so repairing the switch may be an option.
2006 ignition lock assembly -- all the mechanical stuff and switch -- is different (will not fit) the 2005 and earlier cars (and vv) according to the parts sites like Hondapartsnow and others all of which seem to use the same database and pictures.
-- Chuck
-- Chuck
-- Chuck
-- Chuck
hondalovr13
Nov 30, 2019 12:24 PM
