im losing a lot of hp!
i got my car dynoed this satruday and my peak horsepower was only 178.04 with max torque at 123.54. im going to get a diagnostic when i can. i hope it's not a major problem. i was wondering if anyone has had this problem too and if so what do you think i need to do?
btw, i have a arc intake box w/chamber and exhaust.
heres the dyno results....
is the dyno configured right?
I had the same problem before, then I did a leak down test and found out one of my cylinder is behaving funny, the needle doesnt' jump bust slowly goes up do the valve. I then opened up my head discovering that one of the valve spring retainer is about to break.
changed all the retainers when I swapped my cams, everything is fine now.
do a compression and leak down test, people may tell you it's the ARC, trust me it's not. I still have the ARC setup on my car, it dynoed 2 hp higher than stock airbox, and the torqur curve is higher and flatter
good luck and Keep ups updated on what you find
it's not clear.. you got 20hp less on the same dyno/same day as other S2000's?
just wondering as I have seen plenty of charts posted with 170's/180's at the wheels...
anyway.. car looks great..
