I'm swapping axles tomorrow.............
Old Oct 3, 2012 | 06:29 PM
Doug3's Avatar
Default I'm swapping axles tomorrow.............
Since the axles nuts will be torqued and "staked", does that eliminate the need for Loc-Tite?
Old Oct 3, 2012 | 07:01 PM
MM3Kwolik's Avatar
Loc-Tite is most definitely NOT needed. Don't even think about putting that on the threads.
Old Oct 3, 2012 | 08:31 PM
xviper's Avatar
At nearly 250 lb/ft, no Loctite in the world is going to do anything anyway.
Old Oct 4, 2012 | 05:25 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Find the post made by "dwight" that says Billman endorsed. There is new info in there that is very important when working with the axle nut.
Old Oct 4, 2012 | 09:57 AM
dwight's Avatar
I wouldn't be so quick to judge. There's a lot of surface area on a fastener that size. In addition it will be acting on a larger radius.
Compare the 24mm axle nut to 90 ft-lbs for a 12mm lug nut. (Not an application that uses thread locking adhesive, but something off the top of my head and an easy 2:1 ratio.)
Bonding Strength = Material Property of Adhesive * Surface Area * Moment Arm
Surface Area: (assuming the same relative width, in this case 1 thread width, e.g 12mm engagement for the lug, 24mm for the axle): pi*dia*dia
Moment Arm: dia/2
---> Bonding Strength = (Mat Prop * pi / 2) * dia[sup]3[/sup]
From this we see that bonding strength is expected to be proportional to diameter cubed.
So, comparing the lug to axle nut, that's a factor of 8. If the lugs get 90 ft-lbs, then that suggests 720 ft-lbs for the axle nut. Even if the axle nut is getting torqued to 400 ft-lbs, that isn't that much. If we look the other way at those common M6 bolts (10mm heads), they'd be looking at about 11 ft-lbs, which again is pretty much expected. So at a glance, I think it might be fair to say size might not matter too much.
I think the biggest issue larger sized fasteners might not be their size, but their tolerances. With larger sized fasteners the threadlocking adhesive might have a greater thickness which may reduce strength. I'm not sure because the thread will deform as it makes contact so it might be a small effect. I guess the point is, I wouldn't be too quick to dismiss its effectiveness on large fasteners.
On a more practical note, the application guide(pdf) says that regular blue Loctite 243 Threadlocker is good for 1/4" to 3/4" (19mm) fasteners. The 24mm nut isn't that much larger, but they also have plenty of products which are designed for larger fasteners (e.g. 2047, 249, 263, 268).
Nonetheless, using thread locking adhesive is neither warranted nor advised.
Old Oct 4, 2012 | 11:21 AM
xviper's Avatar
I'm happy to see that you expended that amount of math and physics to contradict one tiny little trite statement I made. As it is not my area of expertise, I can neither confirm nor refute your equations.
You are most welcome to not stake your axle nut and just go with Loctite.
Old Oct 4, 2012 | 06:21 PM
QuangNguyen_89616's Avatar
Good one! LOL
Old Oct 4, 2012 | 06:35 PM
Doug3's Avatar
Axle nut was torqued, staked and no Loctite was used. Rear end vibration is gone.
badboy00z
Oct 10, 2010 12:59 PM
hypforlife32
May 27, 2010 10:49 AM
meccjoo
San Diego S2000 Owners
Feb 1, 2008 12:56 AM
ccarnel
Mar 30, 2004 09:22 AM
