Immobilizer Bypass/Defeating
Does anyone have any information on defeating/bypassing the immobilizer? I'm working to eventually install an S2000 engine and transmission etc in to another make of vehicle, and I don
Jim,
Looked into this for an S2000 clubman conversion.,
Even if you bypass the main EFI relay the ECU wont work without a valid key code.
The immoboliser is built into the ECU and uses a simple pickup around the lock barrel. Suggest you get the immobiliser pickup connected somewhere a put a key beside it.
The dealers may try to tell you that the S2000 uses the red/black key system which requires a whole key/immobliser replacement kit. THis is incorrect. The S2000 allows for individual keys to be programmed in/out of the ECU memory.
Good luck
Good luck
Do a search for info about the Spoon ECU. There was a thread recently about a problem relating to the immobilizer in the Spoon ECU. There was a discussion about defeating the immobilizer.
You might also contact Hondata. While they don't offer an S2000 product specifically, they have experience with eliminating immobilizers on Honda ECUs. It would be a custom job and not cheap, but otherwise you might just have to buy a Mugen ECU ($1200+).
UL
UL
Originally posted by SAIYAJIN
You wouldn't by any chance be putting an F20C into a Lotus Elise would you?
