inner and outer tie rod replacement
Old Nov 12, 2013 | 04:07 AM
iamxpl's Avatar
Default inner and outer tie rod replacement
im about to change out my inner and outer rods. the procedure is simple. just needed someone to chime in with any advice or tips before i get started. i dont have the manual so im asking if there are any little tips that the manual has that would not be general knowledge. i know there is a washer that needs to be un-staked. once i get the rods out should i put any kind of grease or lube on the rack ? then anti seize? did i forget anything?
TIA guys.
Old Nov 12, 2013 | 08:57 AM
boyguan's Avatar
Lube the gear if you can. Try not to cut the boot to get the tie rod on. It stretches but not easily.
Perform alignment right away. You can count how man rotations you turned to remove the outer so you can get close. That's only true if your replacement is exactly the same. I'd get a ball joint tool ready just in case
Old Nov 12, 2013 | 09:42 AM
iamxpl's Avatar
i have all new inner and outer rods. i will measure the old ones when installing new set in. what kind of lube should be used? all purpose? i didnt cut the boot. i took off the straps and will slide it off after. i just read the shop manual ( which i just got ) that you will need a 32mm and a 35mm wrench. specialty wrenches since these sizes are not very commonly used. i will try and go to harbor freight and get some adjustables or get the service wrench set. the 32mm and 35mm translate to SAE 1 1/4 and 1 3/8 in. ill be tackling the job when i get home. ill take some pictures and put up a DIY since there isnt one.
Old Nov 12, 2013 | 03:30 PM
boyguan's Avatar
Just use a adjustable crescent wrench
JrJanowski
Jul 25, 2017 01:25 PM
Coaks7
Mar 7, 2017 11:09 PM
riceburners2001
Mar 10, 2006 07:08 AM
LubedKoala
Jul 12, 2005 07:56 PM
Prolene
Feb 20, 2002 05:22 AM
