installation: new brake pads
Old Dec 15, 2005 | 08:30 AM
jah's Avatar
jah
Default installation: new brake pads
new pads are larger and need to compress the piston. unlike the front the emergancy brake keeps the piston in place? where is the best place to loosen the emergancy brake cable. would like to keep the emergancy brake line on the caliper assembly intact so the assembly bolts back w/o issues if possible
Old Dec 15, 2005 | 08:34 AM
Conedodger's Avatar
I haven't done brakes on an S2000 yet, so I maybe wrong. Most cars with rear disc brakes have a slot or groove in the piston so that it can be turned back into the caliper. You shouldn't have to mess with the e-brake cable.
Old Dec 15, 2005 | 09:37 AM
bighead's Avatar
yeah I use a "Brake Cube", it uses a standard 3/8" extension and has 9 different patterns, all you have to do is match it up to the piston and using a ratchet simply screw the piston back in...
Old Dec 15, 2005 | 09:44 AM
boyguan's Avatar
where did u get the cube and how much?
looks pretty good for the rears
Old Dec 15, 2005 | 10:08 AM
jah's Avatar
jah
thanks!
i heard you have to turn it cw 90degrees at a time or make sure the groves are in line with some sort of tab
i called napa: their "Brake Cube" is ~$14.00
Old Dec 15, 2005 | 10:23 AM
JDMwhore's Avatar
You actually dont need anything special, like this brake cube. A regular 3/8 extension will fit right in the middle and allow you to twist it in.
Old Dec 15, 2005 | 11:03 AM
bighead's Avatar
it's a 'nice to have' item... especially if you work on several different cars all with different methods of turning the piston.
But yeah I got mine from Pep Boys I believe and it was in the same ballpark as the napa item.
Old Dec 15, 2005 | 12:39 PM
boyguan's Avatar
on the back of the rear pad there is a small notch. you want to try to get it aligned with the piston. technically if you dont it will still line up sooner or later but you will have a sudden loss in pressure when it does.
Old Dec 15, 2005 | 12:55 PM
foolio's Avatar
I initially didn't align my rear brake pads to the notch, and it caused uneven wear on the pad.
I make sure to test fit the pad before I bolt it up now.
Old Dec 15, 2005 | 01:18 PM
gfacter's Avatar
The E-brake cable adjuster is under the center console, just pull up the rectangle shaped piece (where you arm rests, it just unsnaps) then use a 10mm wrench to loosen the cable.
