Installed test pipe
Old Feb 8, 2010 | 12:51 PM
Requiem's Avatar
Default Installed test pipe
I bought a Invidia test pipe from a member on the forums. It was in good shape and he said it had the CEL fix on it. However, after about 10 minutes of driving a CEL came on. Is there anyway to turn it off?
Old Feb 8, 2010 | 01:05 PM
wisdom's Avatar
You can turn it off if you have non OEM EMS.
Try using another spark plug anti-fouled. I used two and mine and no CEL. I didn't even bother using one.
Old Feb 8, 2010 | 01:19 PM
DFWs2k's Avatar
use a code reader to pull the code and then erase it, mine did it 2-3 times in 200 miles, and then only 1 more time in the next 15,000 miles
Old Feb 8, 2010 | 04:50 PM
siik_ap2's Avatar
not to sound like an ass but is the code your getting even for the secondary o2 sensor??? u have a pic of the cel fix??
Old Feb 8, 2010 | 08:14 PM
JDMQuip's Avatar
Don't the Invidia's have the built in CEL fix? Any who, you have an 00' so it shouldn't be the picky. I have a Berk testpipe and no CEL for almost 2 years now.
Old Feb 8, 2010 | 08:16 PM
Slows2k's Avatar
You need the code before assuming it's the test pipe.
Old Feb 8, 2010 | 11:50 PM
Bewbies's Avatar
I have the Invidia 70mm Test Pipe with CEL fix on MY03 like the previous user said get a couple non-foulers from kragen (its like $4) but if you do that you need to drill out the one you are going to screw the o2 sensor into with a 1/2" drillbit. Or you can buy them for $8-15 on ebay
Old Feb 9, 2010 | 03:32 AM
Requiem's Avatar
It came on after installing the test pipe.
Old Feb 9, 2010 | 07:04 AM
4evertopless's Avatar
So? It could be a lean code, not a secondary o2 fault. Just goto a local auto parts store and ask them to read the code for you. Its free and takes less than 3 minutes from walk in to drive off.
Old Feb 9, 2010 | 08:47 AM
alSpeed2k's Avatar
^or just search for the paperclip trick and pull the code yourself.
