Installing rocker arm assembly
Old Dec 28, 2007 | 11:00 PM
TheCarGuy2021's Avatar
Default Installing rocker arm assembly
Well I've got my 3mm head gasket in and the head torqued back down, but now I'm trying to put the rocker arm assembly back on. The thing is very difficult to get back on, those lil buggers keep moving around and getting in the way etc. Any tricks to getting it back on? The helms simply says "install rocker arm assembly".
This is where I'm at:
Thanks!
Old Dec 28, 2007 | 11:23 PM
GizmoIsChinese's Avatar
Put rubber bands to hold them together, then cut them off once their installed?
Old Dec 28, 2007 | 11:46 PM
Then the spark plug tubes won't be able to go through. The Vtec rollers are also too short to rubber band together. I will give it a try when I wake up though if there are no other ideas.
Old Dec 29, 2007 | 08:29 AM
Slows2k's Avatar
You can zip tie the rockers together.
Old Dec 29, 2007 | 08:33 AM
Brilliant.
Bryan858
Feb 21, 2019 10:49 AM
Lair
Sep 10, 2017 05:03 AM
rob.ok
Mar 25, 2010 09:38 PM
abv
Feb 13, 2008 11:03 PM
skibum
Oct 8, 2007 05:18 PM
