Intake Manifold removal DIY?
Old May 26, 2020 | 08:29 AM
WarrenW's Avatar
Default Intake Manifold removal DIY?
Has anyone done a DIY on the intake manifold removal/replacement? Yes I did a search and found nothing. I have to remove the intake manifold to get to the rear clamp on the upper radiator hose.
Old May 26, 2020 | 09:08 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Definitely do not remove the intake just for that hose.
Once you get some things out of the way (iac valve, small other things) a cable operated clamp tool can take that spring clamp right off.
Taking the intake manifold off is a big job, and there are lots of hoses and wires that will likely get bunched in the wrong position upon installation, unless you are a veteran mechanic.
This tool:
https://www.bing.com/aclk?ld=e8cooBY...0b&adlt=strict
Old May 26, 2020 | 09:29 AM
WarrenW's Avatar
This tool:
Thanks Billman but I tried that tool and still can't get the clamp off. It's been an enourmous pain. I started the manifold removal process but so far am only up the removal of the fuel rail and injectors.
Old May 26, 2020 | 10:17 AM
snitm's Avatar
As someone who has taken his IM off and reinstalled multiple times, upgraded to different IM, etc: If you cannot get to that clamp without taking the IM off you have no business taking the IM off..
Honda should be able to get to that clamp for you... although they'll complain about it.. just take it there.
Old May 26, 2020 | 10:26 AM
afzan's Avatar
taking the 00-05 intake manifold off is a very time consuming job, definitely listen to billman's advice above
SuperHamz
Apr 23, 2019 02:08 AM
scottdh20
Mar 24, 2019 07:08 PM
Curated Content Editor
Feb 14, 2019 10:55 AM
HwangTKD
Jan 24, 2017 12:56 PM
davidc1
Jul 20, 2016 01:05 AM
