intermitted engine shut off
Old Jul 5, 2023 | 10:48 PM
RolanTHUNDER's Avatar
Originally Posted by youngcow
Yes sir, currently the ballade motorsports one is in the car. Both did the same thing. The original one threw a TPS code so that one is useless.
Damn. Then it's not the TPS. Kind of makes sense because they rarely ever go bad. Is there anything else you've tried?
Old Jul 15, 2023 | 01:01 PM
VRYANTEC's Avatar
I had a similar issue awhile back and it ended up being my MAP sensor. You can get them cheap, may as well give it a try.
Old Jul 15, 2023 | 01:49 PM
windhund116's Avatar
Should this symptom(s) generate some sort of CEL code?
Thanks!
Old Jul 17, 2023 | 12:45 AM
Thanks!
As far as I know, no
Old Aug 1, 2023 | 04:53 AM
youngcow's Avatar
Sorry I keep forgetting to check this post, I thought I had alerts set up. But, yes I bought a MAP sensor from hardtopguy, and the map sensor tsp zip tie. Still didn't work or help.
I'm at a complete loss.
Old Aug 1, 2023 | 04:55 AM
youngcow's Avatar
Yes, I've tried IACV (idle air), MAP sensor, replaced injector seals cause one was bad (it helped but didn't completely stop the problem), and cleaned the throttle body fuel induction service.
No it does not.
Thanks!
Thank you everyone for your replies. I'm not sure what to do anymore.
Old Aug 1, 2023 | 06:14 AM
Electrical connections to battery clean and tight? All ground points good? Battery is healthy?
This video may help. You can bypass the CEL portion, in the beginning.
Old Feb 26, 2024 | 05:46 AM
youngcow's Avatar
Update: I've tried everything and I had a buddy tell me to try a new fuel pump considering the age of the car and the symptoms.
I got myself a AEM fuel pump. The car runs better, it doesn't shut off as often but still shuts off randomly.
Thank you everyone for your suggestions. I'm at my wits end I have no idea what to do anymore. At some point I might just have the engine rebuilt or something. Not sure where to go from here.
Old Feb 26, 2024 | 05:59 AM
Have you ever run a heavy-duty aftermarket clutch pressure plate?
Thanks!
Old Feb 26, 2024 | 06:13 AM
youngcow's Avatar
Thanks!
I run the Stock disc, HD ACT PP and ACT race flywheel combo. I don't believe this is the culprit only because this issue was happening before I installed this clutch.
