Intermittent Surging While In Vtec...
Old Jul 21, 2004 | 01:12 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Default Intermittent Surging While In Vtec...
Well, my S2000 is having it's first driveability episode in 27k miles. While in VTEC, whether WOT or holding steady from 6-8k, the engine intermittently surges. It FEELS like the VTEC solonoid is kicking on and off, but not at that extreme. It's a mild surge, like it's dropping 20 hp on and off. I will get to the bottom of this eventually, and post what I find, but was hoping someone here had experienced something similar. I have already pulled the VTEC valve, checked the screen, checked the piston for free movement. I have ran it low on fuel and filled it with fresh Amoco, no change. Oil is on the full mark. This happens about 40% of the time while in VTEC. It seems to pull smoothly at WOT below 6k. So, If you have had something similar, or heard of someone who has, It would be most helpful. THANKS.....
I will hook it up to the scanner and run some datastream tonight. I wonder if the VTEC system on/off can be read with the datastream....
Progressive checklist...
..Oil is full, Mobil1 with about 500 miles
..VTEC valve/screen is clean, moves freely
..Fresh fuel, no change
..valves adj about 12k miles ago
Old Jul 21, 2004 | 03:31 PM
Liemoanh's Avatar
I think I know exactly what your experiencing. My car did this for a month. I thought it was my clutch slipping through Vtec. It would do this every single time I hit Vtec. Then one day it stop, WTF! It pulled great all the way through Vtec. How is this happening?
I came home and did some researching and found the thread about the famous MAP SENSOR. Went to my car, gave the MAP SENSOR a couple of beatings and reseted the ECU.
My car pulls fantastic now, all the way through Vtec. Hope this helps for you.
Old Jul 21, 2004 | 04:45 PM
Billman250's Avatar
Top Answer: 1
Thanks for the reply bro, our problems sound very similar....Hooked up the scanner tonight to do some flight recordering; the dam car ran perfect all night. Maybe it was the quickie I did on the VTEC valve, who knows....I'll keep this updated if anything changes...
Old Jul 21, 2004 | 06:04 PM
Venomous S's Avatar
A couple of good drifts should fix the problem. I know someone that can do them real good...
Old Jul 21, 2004 | 07:36 PM
Slows2k's Avatar
Billman, You can watch VTEC solenoid on with a Honda PGM-FI scan tool. I don't know what software/scanner you are using if it will be supported. I've had a flakey coil pack (caused by and oil leak) on another S intermittently bug out causing similar issues. The car had Misfire DTC's stored in history, and had oil leaking into the #2 spark plug tube, from the tube seal in the valve cover.
Old Jul 21, 2004 | 07:46 PM
Hyper-X's Avatar
Kind of off-topic but..
Slows2k, what became of your Toda issue?
Old Jul 21, 2004 | 08:05 PM
Slows2k's Avatar
It's still broke, and Toda did not warranty it. Since mine was broken, 2 other NA cars have had the same bracket break. So much for Toda blaming the SC.
Old Jul 22, 2004 | 08:31 AM
Billman250's Avatar
Top Answer: 1
Thanks Slows2k, I'd really like to get my hands on a Honda pgm-fi. My Matco determinator $3500 scanner won't support the v-tec data....I'll try some figure 8's and see if I can get the problem to recur. BUMP...anybody else??
Old Jul 22, 2004 | 02:58 PM
Slows2k's Avatar
If you can find a Vertronix Mastertech it's the same tester as the PGM-FI unit. You just have to load the Honda software on it.
Any history misfire DTC's?
Old Jul 23, 2004 | 04:27 AM
MyBad's Avatar
Subscribed.
