invidia exhaust fitment problems
I just got my invidia n1 single outlet exhaust, and its great except for 1 thing...the exhaust wont fit flush with the rear bumper. there is a bar that runs across the underside of the rear of the car that is preventing the exhaust from sitting up higher...it is marked with an A if that helps. I'm not sure what its actually called...but anyway..what can I do to make it sit flush in there? Do I need to take it to a shop and have them bend the exhaust a bit? It hangs down about an inch, maybe a tad bit less.
Former Sponsor
Arn't you suppose to run the pipes under that bar? Since you didn't do that first, you can unbolt that bar on each side, then re install it with the exhaust behind it.
Mine sits a little low in the rear bumper but it is not because of the bar its because how it was designed. I am planning to get some shorter rubber hangers to bring it up a bit.
yea mine sits about an inch low also. i want it to be angled up a little bit higher so i might take it to a muffler shop to shorten the hangers a bit to see if it raises the muffler.
