Issue with oil change.
Old May 10, 2004 | 12:36 PM
Veneficus's Avatar
Default Issue with oil change.
So I tired to do my first oil change on the S. I followed Xviper's thread on how to do it. Once I started the car up to get the oil flowing it started to spurt out everywhere and I rushed and turned the car off. It looks like all the oil was spit out and much of the under carriage was covered with oil.
I wanted to ask about some advice on what could have happened. I think it might be the oil filter, maybe it wasn't on tight enough. I know I torqued the oil pan to the correct ammount and I tightened the filter by hand.
I'm using the Hamp oil filter by Blue Fin Tuning. Might that be a problem with a s/c engine?
Any advice would be helpful.
Thanks guys,
Dan
Old May 10, 2004 | 12:48 PM
Ravenwerk's Avatar
If most of the oil seems to be down low I would think it came from the filter. I'll hazard a guess that the old ring seal from the first filter didn't come off when you changed filters - in essence you have two rubber ring gaskets in place (which will not give a good seal).
Old May 10, 2004 | 12:49 PM
Veneficus's Avatar
Thanks I'll check out the ring seal issue, I had not thought of that.
*I just checked the old filter and it does not have the seal on it. Sometimes you feel like a total idiot when you make mistakes like this.
So the Hamp Filter from Blue Fin Tuning should be fine, other then my seal issue?
Old May 10, 2004 | 01:08 PM
CrazyPhuD's Avatar
Just put my HAMP in this weekend no problems.....guess the gasket is the problem. Did you look at your old oil filter to see if some of the rubber is missing?
Old May 10, 2004 | 01:21 PM
Ravenwerk's Avatar
I ordered a case of them from speeeding. Used two so far with no issues. I do recall someone claiming that one he installed felt like it "bottomed out" while tightning it down and didn't seem to seal very tight.
Many other owners seem very happy with them. Roadrage recomends (and uses) the Honda PDX but I don't think he has tested the HAMP yet.
Old May 10, 2004 | 02:35 PM
Veneficus's Avatar
[QUOTE]Originally posted by CrazyPhuD
Old May 10, 2004 | 04:35 PM
QIKSILVR's Avatar
Common "noobie" mistake.. no worries, as long as you shut down right away, it just made a mess.. In the future, ALWAYS double check that the old rubber seal came off the oil filter by checking the base on the engine.
Old May 10, 2004 | 04:44 PM
Road Rage's Avatar
[QUOTE]Originally posted by Veneficus
Old May 10, 2004 | 04:51 PM
xviper's Avatar
Just so that noone thinks I steered anybody in the wrong direction with missing information, here is an exerpt and quote from my oil change "How To":
Originally posted by xviper
remove the filter and make sure the filter gasket ring is NOT stuck on the side of the engine.
Old May 10, 2004 | 05:27 PM
Veneficus's Avatar
I wasn't mislead I was just using your write up as a brief reference; I should have read it more thoroughly. But I in fact was under the impression that I had removed the seal and cleaned away the extra oil drippings. This it's my fault that I did not double check, I'm just glad I had the help to guide myself where to check again.
The write up was excellent as they are whenever I use them. Just my own negligence, but we learn from our mistakes though.
