Issues after AP1 Retainer swap
Old Apr 1, 2020 | 06:22 PM
Oironet's Avatar
Default Issues after AP1 Retainer swap
Hello,
Recently, I performed a retainer swap on my ap1, adjusted the valves and changed out the spark plugs with new oem parts. After putting the car back together and getting no OBS codes or errors on start up, I am now realizing the car is louder, makes less power and the rattling sound coming from the engine bay is very loud.
Below is a link to 8 seconds of the engine idling.
https://photos.app.goo.gl/CnET7wG8vK1CSojC6
Any help would be greatly appreciated.
Old Apr 1, 2020 | 06:44 PM
starchland's Avatar
Were they tight before? Sounds ok to me
Old Apr 1, 2020 | 06:53 PM
Oironet's Avatar
I forgot to check before I did the work, and the sound comes from the right side of the engine very loudly.
Old Apr 1, 2020 | 06:56 PM
Iyan112's Avatar
passenger side? Have you checked your oil level or TCT tensioner?
Old Apr 1, 2020 | 07:04 PM
Oironet's Avatar
Yes, oil level is good at about 5 quarts, and TCT is fine.
Old Apr 1, 2020 | 07:09 PM
Iyan112's Avatar
Common mistakes made with valve adjust that you used Inches Instead MM or you swapped intake and exhaust measurements. Possible you might of done so?
Old Apr 1, 2020 | 07:17 PM
Oironet's Avatar
Just checked, I used mm and I used the correct measurements for intake and exhaust.
Old Apr 3, 2020 | 04:51 AM
Jim Bravo's Avatar
If your valve clearances are correct, I'd double-check that all of your retainers have both keepers in them.
I'd also check that your rocker pins are all in place, which might be tough without pulling the cams back out.
This would give you a chance to make sure your cam caps aren't cracked, and are torqued back down properly.
Start with these things.
Old Apr 6, 2020 | 09:06 PM
jyeung528's Avatar
have you ever adjusted the valves on this car?
na2king
Oct 13, 2016 08:46 AM
DZero
Oct 10, 2016 05:15 AM
